Ansys Learning Forum Forums Discuss Simulation General Mechanical Reducing Result File Size in Transient-Thermal-Electric Simulation Reply To: Reducing Result File Size in Transient-Thermal-Electric Simulation
m_gonser
thank you for the response! Yes, I referred to the link you sent.
in the sulution information, in the beginning, the default value is the following:
Then i try to overwrite the output control table, with the code above, which seems to work at first:
But at all the following load steps, the output control options are overwritten again
