Ansys Learning Forum › Forums › Discuss Simulation › Fluids › 10 year HX model › Reply To: 10 year HX model
RAJEH
I am trying to simplify the problem here. These are codes for dynamic boundary conditions. The first hour (Temperature = 30, and mass flow rate= 0.583) the second hour (Temperature = 30, and mass flow rate= 0), the third hour (Temperature = 6, and mass flow rate= 0.583), the fourth hour (Temperature = 30, and mass flow rate= 0). I am not getting the results that I expected. Do you have any suggestions for me to correct or use another approach to write my codes?
DEFINE_PROFILE(give_T_top_outerfluid,t,index)
real time=RP_Get_Real("flow-time");
real total_time = 0;
begin_f_loop(f,t)
total_time = total_time + ceil(time);
if(total_time <= 3600 )
F_PROFILE(f,t,index)= 30 +273.15;
else if(total_time > 3600 && total_time <= 7200)
else if(total_time > 7200 && total_time <= 10800)
F_PROFILE(f,t,index)= 6 +273.15;
else
end_f_loop(f,t)
DEFINE_PROFILE(give_mass_flow_rate,t,index)
begin_f_loop(f,t)
F_PROFILE(f,t,index)= 0.583;
F_PROFILE(f,t,index)= 0;
else
end_f_loop(f,t)
Attached are graphs of the physical goal of writing the codes.
