Ansys Learning Forum Forums Discuss Simulation General Mechanical Point Loading of Cantilever Beam Results does not match with Theoritical Results Reply To: Point Loading of Cantilever Beam Results does not match with Theoritical Results
peteroznewman
You are misreading the contour plot you included in your post. The end of the beam colored red is attached to the wall and has deflection of 8.9284 e-6 inches, which is numerically equal to zero.
The tip of the beam colored blue that has the load applied has a deflection of -0.0068 inches which is close to the expected value of -0.0071 inches.
