Ansys Learning Forum › Forums › Discuss Simulation › Photonics › FAQs -search topics written by Ansys-Lumerical Engineers › Reply To: FAQs -search topics written by Ansys-Lumerical Engineers
Guilin Sun
Ansys Insight: Getting material data from the material group
Ansys Insight : Visualize the CW response of a plasmon mode
Creating 2D Conductivity from Permittivity Data
The Plasma (Drude) Material Model and some corrections to the model
Questions Regarding Autoshutoff level
Lumopt - Custom Figure of Merit
How to include propagation loss and coupling coefficient in ring resonator
Ansys Insight: Small bent waveguide
Ansys Insight: Calculate the "Modal area" of a mode
Ansys Insight: How to define the refractive index of graphene
Ansys Insight: Tips for sweeping single frequency simulations
Ansys Insight: Scattering rate in surface conductivity of graphene
Ansys Insight: Single frequency CW source
Ansys Insight: Creating lossless materials
Best approach for simulating large ring resonators
Ansys Insight: Tips on running FDTD simulations
Ansys Insight: Calculating the response to an unpolarized beam
Ansys Insight: How close can monitors be to other objects
Ansys Insight : How close can monitors be to other objects?
Ansys Insight: Compiling your plugin material in Windows
Ansys Insight : Draw structure outline in visualizer
Ansys Insight: Did my simulation stop before the auto shutoff minimum was reached?
Ansys Insight: Custom TFSF source
Ansys Insight: About override mesh in FDTD Solutions: its use and settings
Ansys Insight: Difference between ''Maximum Generations'' and ''Generation size'' in Optimization
Ansys Insight: Why my simulation result is different from published paper or experiment?
Ansys Insight: How to correctly set the boundary conditions in FDTD simulations
Run large number of parallel simulations(reply to questions)
Ansys Insight: Slow convergence in FDTD
