Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unconverted solution Slab simulation › Reply To: Unconverted solution Slab simulation
November 23, 2021 at 3:40 pm
Ok.
It seems like from the messages you get substeps converging. Can you share a snapshot from the Solution Information Force convergence plot please. If you look at the results up to the point of non-convergence, do they look plausible and the material is behaving as intended up to that point. Are there any warning or error messages in the solution information, solver output that indicates other issues?
Regards Sean
