Ansys Learning Forum Forums Discuss Simulation General Mechanical Error when open in the version: ANSYS 2021 R2 Reply To: Error when open in the version: ANSYS 2021 R2
Sahil Sura
Did you try importing material file (.xml format) from the older versions, this can be the reason for the error to cause as Ansys officially supports opening files from up to two versions back. So you might want to recreate the new material file in new version itself using the graphical user interface entries in Engineering data.
Hope that helps.
Thanks Sahil
