Ansys Learning Forum Forums Discuss Simulation General Mechanical Unknown Error Involving Node Limit Reply To: Unknown Error Involving Node Limit
sahil.sura
Cyclic symmetry allows user to model a sector but obtain non-symmetric response for entire structure, thus the node limit for the structure needs to be satisfied. i.e. on expanding the solution for your problem, the node limit of the academic version has exceeded. You may try going for a bigger sector (1/6th or 1/4th) with same number of elements or edit the mesh accordingly for current using some of the methods mentioned in the following resources to get the number of elements/nodes in the limit. Also contacts add a virtual node, thus there is a possibility to go over the limit for complex models with lower node counts.
Cyclic Region Overview (ansys.com)
Mesh (ansys.com)
Problem size limits are
Structural Physics: 128K nodes/elements
Fluid physics: 512K cells/nodes
LS-DYNA: 128K nodes/elements
Electromagnetics: N/A
Please check the following link for new version-Ansys Student Versions | Free Student Software Downloads
Thanks Sahil
