Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Cascaded S-parameters Interconnect › Reply To: Cascaded S-parameters Interconnect
iiskanda
Following up on my previous post, I'd like to mention that I connect the S-parameter elements with straight waveguides and attenuators as in the image attached. Is there any case that I connect wavelength-dependent elements (S-parameter) with non-wavelength-dependent (straight waveguide + attenuators) that causes the problem?
Regards Ilias
