Ansys Learning Forum › Forums › Discuss Simulation › Materials › Can any one tell me which Material model has to be used for the plastic material ” Nylon 6/6″….? › Reply To: Can any one tell me which Material model has to be used for the plastic material ” Nylon 6/6″….?
November 2, 2021 at 4:22 am
Hi Mr. Ram
Thankyou for reply Mr. Ram.
Following are the details of the analysis.
1. Structural Analysis, specifically static structural analysis where a beam is subjected to 3 point bending.
I need to compare the max deflection that will occur while using isotropic behaviour of nylon 6/6 (which i have already done) and non linear behaviour of Nylon6/6. I have referred few literatures and they use non-linear visco-elastic material and the model is assumed to have large deformations, and the constitutive model is based on the Prony series.
What is your suggestion regarding the same.......?
