Ansys Learning Forum Forums Discuss Simulation Fluids Properly establihsing Boundary Conditions Reply To: Properly establihsing Boundary Conditions
I'd use a velocity boundary with a negative component/value and two pressure inlets. Vent is intended for something else (read the User's Guide) as I can't remember the definitions.
Floating point could be mesh or boundary condition related. Just because the cells are good doesn't mean the mesh is: you may not have resolved the flow features sufficiently.
