Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › How to resize the particle diameter › Reply To: How to resize the particle diameter
November 1, 2021 at 1:32 pm
Administrator
Are you using 'Pathlines' to visualize the flow (no DPM)? Or is this a DPM simulation? If it is a DPM simulation, you should be able to directly change this under 'Injections'.
If I did not understand your question properly, please share some screenshots.
Karthik
Karthik
