Ansys Learning Forum Forums Discuss Simulation Photonics Getting Error “In set, the requested object number is out of range” Reply To: Getting Error “In set, the requested object number is out of range”
Guilin Sun
You are right that "set" is used when an object is selected, no need to mention its name. Whereas "setnamed" will specify the object name.
