Ansys Learning Forum Forums Discuss Simulation Fluids Re: High aspect ratio Reply To: Re: High aspect ratio
Karthik Remella
Administrator
Yes! Your understanding is correct. Try plotting the parameter "Cell Wall Distance'. It is the distribution of the normal distance of each cell centroid from the wall boundaries. Two times this value is your first layer thickness.
