Ansys Learning Forum Forums Discuss Simulation Fluids Re: High aspect ratio Reply To: Re: High aspect ratio
karthik.remella
Administrator
You don't need to solve the model. You can initialize the model and plot this wall distance. You should see the correct first layer thickness you specified for meshing the model (within reason). If you see really high or low values, then you are looking at some erroneous results.
Karthik
