Ansys Learning Forum Forums Discuss Simulation Fluids Re: High aspect ratio Reply To: Re: High aspect ratio
vsjay3
Thank you very much for your response. Appreciate it.
(I hope it works because I cannot reduce the length of inflation cells (parallel to wall) since that will increase the total number of elements and I am using the student version of Ansys Fluent).
As for your question - I have not run the simulation yet. To plot the wall distance contours, I have to first run the complete simulation right? Or is there a way to check that before running the simulation?
Also, since I am new to Fluent, may I know what the anomaly will look like (as an example) when I do plot the contours?
Thank you very much!
