Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How to extract values from Mode List data in Eigensolver Analysis › Reply To: How to extract values from Mode List data in Eigensolver Analysis
mwhitby
My apologies for the repeated comments. I only meant to add it once but there must've been some sort of system error.
Thank you for your help! I am having some slight issues while trying this.
Firstly, the loss = getresult("mode1","loss); code outputs loss = 509627 whereas in the table for mode 1 loss is listed as 5096.3. Is this a scale problem? Is there a way to fix this?
Secondly, the E = getresult("mode1","E"); code doesn't give me the TE polarization fraction. It says that E = E vs x, y ,z ,lambda/f. How can I get this to give the TE polarization fraction?
