Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › How can i add JH-2 model in WB LS DYNA ? › Reply To: How can i add JH-2 model in WB LS DYNA ?
Ram Gopisetti
from 2021r2 of ANSYS, there is an native support to simplified and JH2 material model from the engineering data.
if you are using any older version of the plugin, you might need to use command taken from the LS-PREPOST .k file
cheers, Ram
