Ansys Learning Forum Forums Discuss Simulation LS Dyna How do I change the smoothing length of SPH Meshing in Ansys work bench ? Reply To: How do I change the smoothing length of SPH Meshing in Ansys work bench ?
Akshay Maniyar
If you insert a Section object from the LSDYNA Pre tab and scope the section to a particle body, the SPH Controls section appears in the Details panel and includes 3 parameters as shown in the figure below:
regards Amaniyar
