Ansys Learning Forum Forums Discuss Simulation Photonics An inquiry regarding simulating hollow cylinder Reply To: An inquiry regarding simulating hollow cylinder
Guilin Sun
From you description: "the inner cylinder will be covered from sides and top by another hollow cylinder", could you set them successfully in GUI by hand? if so, you can do this by script.
You will need two scripts to modify the mesh order:
1:
