Ansys Learning Forum Forums Discuss Simulation Fluids Standard Initialization and Patching is not applying at the boundary Reply To: Standard Initialization and Patching is not applying at the boundary
Can you check you patched the correct fluid domains? The obvious hiccup is not patching the top cylinder.
