Ansys Learning Forum Forums Discuss Simulation Fluids Standard Initialization and Patching is not applying at the boundary Reply To: Standard Initialization and Patching is not applying at the boundary
gindi
I did that actually. Exactly the same as the one I had earlier. Three fluid zones named as I mentioned earlier, and the boundary conditions set similar to those I had before.
I will give it another try and rebuild the whole model again as a recheck. I will keep you posted.
