Ansys Learning Forum Forums Discuss Simulation Fluids Regarding the setting of physical properties Reply To: Regarding the setting of physical properties
You'll need a UDF or expression to set the function up. Or is the cp a function of time at a temperature with a history component? For that you'll need a UDF and UDM to store the history part.
