Ansys Learning Forum Forums Discuss Simulation General Mechanical How to couple nodes to an unused node and applied a load to it? Reply To: How to couple nodes to an unused node and applied a load to it?
ErKo
Hi
Since you are using large defections, you cannot use CERIG RBE3 (they are only for small deflections).
So you have to use MPC contact elements or MPC184 elements (a spider wheel is needed like you show in the CP image in your first post) for that see this helpful post on how to define them (mpc184 "spider" wheel).
All the best of luck
Erik
