Ansys Learning Forum › Forums › Discuss Simulation › Photonics › No results in ONA when reading one of the outputs of waveguide coupler › Reply To: No results in ONA when reading one of the outputs of waveguide coupler
Guilin Sun
When there is no result, it means actually the magnitude is too small so to ignore it. I do not know what you modified, but using the online ring resonator example, I got result from port 4
all light is in this port:
settings:
Please check your settings and try again.
