Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Contour Plot using Sliding Mesh Methods shows Discontinuity › Reply To: Contour Plot using Sliding Mesh Methods shows Discontinuity
It's not usually that pronounced a problem and the cell size isn't too dissimilar in the mesh image. If you replot the contour with node values off it'll highlight if you've got a high gradient in that region which can result in some distortion in the results.
