Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Contour Plot using Sliding Mesh Methods shows Discontinuity › Reply To: Contour Plot using Sliding Mesh Methods shows Discontinuity
SitiMN
Yes, I can see the cell discontinuity on the same surface (as indicated by the red box). This is probably due to the internal is rotating whilst the outer part is stationary, thus after running the simulation the cells do not align properly. Is there any way to smooth this in the contour plot?
Thank you.
