Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Simulation stuck at TAU Mesher › Reply To: Simulation stuck at TAU Mesher
October 29, 2021 at 1:46 pm
Hi @msamet
Try changing the meshing from TAU to Classic under initial mesh settings.
Also, it is not advisable to have such sharp bends at the corners, I suggest you add some curvature at the corners which is more practical and makes meshing easy.
Regards Navya
Regards Navya
