Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Unable to run mpi jobs on a cluster › Reply To: Unable to run mpi jobs on a cluster
kindires
Hello Ok, we were already setting the ANSYSLMD_LICENSE_FILE variable when we loaded the Lumerical module. I found out that I had a License.ini file with the wrong domain number (0 instead of 2).
The hint came from the reference to Ansys Enterprise solver in the error message!
BTW, the page you reference also says License.ini settings take precedence over ANSYL_LICENSE_FILE variable. It was clearly a mistake on my part.
Thanks again for your help.
