Ansys Learning Forum › Forums › Discuss Simulation › Fluids › [ERROR] The Quad Mesher failed on one or more faces. › Reply To: [ERROR] The Quad Mesher failed on one or more faces.
October 28, 2021 at 4:36 pm
It won't be, and I suspect the skew on the tri elements is fairly high. In CFD terms I'd tend to expand the contact region a little bit to remove the tangential intercept: I'm a little surprised the CAD worked too as that's a "non manifold body" and tends to cause problems.
