Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The simulation results obtained by Windows and Linux are different › Reply To: The simulation results obtained by Windows and Linux are different
That should give the same result. Can you post contours of velocity etc to see what else is going on? Has anyone else checked your model set up, and are you using any UDF code?
