Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DPM Drag Law UDF Error › Reply To: DPM Drag Law UDF Error
If you copy and pasted direct from the manual can you check for white space characters. There's a good chance there's something in there that's mimicking a return/tab/space and messing with the code. However, that usually causes the compiler to fail.
