Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Latent Heat In Fluent › Reply To: Latent Heat In Fluent
Then you'll need to change the units and convert your values. Check the enthalpy units in Fluent just in case you can change those rather than looking up the conversion factors.
