Ansys Learning Forum Forums Discuss Simulation Fluids How to Simulate Particle Deposition on Membrane Surface Reply To: How to Simulate Particle Deposition on Membrane Surface
If the membrane is a porous media you set the properties on that. You use a PJ as the bounding surface and ensure resistance is zero, but use it to assign particle bc's.
