Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to Simulate Particle Deposition on Membrane Surface › Reply To: How to Simulate Particle Deposition on Membrane Surface
If Fluent is creating walls at these locations you'll not get any flow either. Can you check the model set up? Please post a few images of the pressure & velocity field.
