Govindan Nagappan
You will have to use APDL commands to modify T and N.
Cross sections can be defined in geometry editor(DM, SCDM) or Mechanical.
For T and N, right click on line body under geometry branch in Mechanical and insert command. Use secdata command to overwrite the defaults.
