Ansys Learning Forum Forums Discuss Simulation 3D Design Error cutting body Reply To: Error cutting body
Aniket
I am sorry my French is as good as Google can translate, but can you try another plane instead of the one passing through the YZ plane? do you have the same behavior then.
Instead of using split bodies, have you tried to split faces? and then detach the faces so that you can create separete bodies?
-Aniket
