Ansys Learning Forum › Forums › Discuss Simulation › Fluids › heat transfer coefficient inside a pipe with constant heat flux › Reply To: heat transfer coefficient inside a pipe with constant heat flux
October 26, 2021 at 9:14 am
Area average? Plot contours? Make sure you read the https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/flu_ug/flu_ug_fvdefs.html definitions to understand which reference values are used.
