Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent doesn’t work through Workbench Reply To: Fluent doesn’t work through Workbench
One for or but if you're using VPN try turning that off. The other option on the launcher is to set the IP interface to 127.0.0.1 and see if that helps.
