Ansys Learning Forum Forums Discuss Simulation Fluids Why isn’t patch working in batch mode (Fluent) Reply To: Why isn’t patch working in batch mode (Fluent)
Thanks Just a note, always use / at the start of the command, ie
/adapt/mark-inout-cylinder yes no 0.20500 0.20500 -0.094500 -0.015130 0.06495190 0.20242480 0.040
To force Fluent to use the full command path from the root menu. Otherwise if the command is triggered from /display it'll fail as it's looking for "adapt" in the display menu tree.
