Ansys Learning Forum Forums Discuss Simulation Photonics Average temperature rise calculation in Diabolo antenna plasmonic heat generation Reply To: Average temperature rise calculation in Diabolo antenna plasmonic heat generation
niazulkhan
I understand that. But then the average temperature will not match the theoretical values calculated by the equation: q=s*k* (temperature rise) mentioned in the paper below. The equation is for semi-infintie heat disk (which is true for 100um x 100um also) and not a function of the total area.
[1]Z. J. Coppens, W. Li, D. G. Walker, and J. G. Valentine, "Probing and Controlling Photothermal Heat Generation in Plasmonic Nanostructures," Nano Letters, vol. 13, pp. 1023-28, 2013.
