Ansys Learning Forum Forums Discuss Simulation General Mechanical Weird strain spikes in a cylinder with varying thickness Reply To: Weird strain spikes in a cylinder with varying thickness
Sean Harvey
Hello @adityap You are welcome. When we bend the tube, one side will experience tension straining, the other compression from the moment that is present due to the force applied. Does this clarify? Thanks.
Regards Sean
