Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Property Macros for porous media with LTNE › Reply To: Property Macros for porous media with LTNE
October 29, 2021 at 5:17 am
Thanks for the reply.
Yes, the heat transfer coefficient that I want to add depends on these factors which themselves depend on temperature of the fluid cells. If not on the forum, if I use licensed technical support, can I expect the solution?
Also, I am looking for the tutorial (please see the attached figure) which is an old tutorial for LTNE along with the UDF used. It isn't available on net anywhere. So, if you could provide it, it would be of great help.
