Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Property Macros for porous media with LTNE › Reply To: Property Macros for porous media with LTNE
October 28, 2021 at 2:35 pm
Administrator
Hello
Your first question will require macros that are not documented in our User Guide. Because of this, unfortunately, we will not be able to answer this question on the forum. Having said that, you should be able to use Fluent Expressions to define the heat transfer coefficient between your solid and fluid porous region. It looks like you are talking about using an analytical expression.
Karthik
Karthik
