Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with C_YI(c,t,i) › Reply To: Problem with C_YI(c,t,i)
October 27, 2021 at 1:40 pm
So the value doesn't exist and is then called. Can you initialise and then hook up the code? You're defining real yinput =C_YI(c,t,i); but depending on the order things are called C_YI(c,t,i) has no value until it's initialised.
