Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Simulate contact from a washer › Reply To: Simulate contact from a washer
October 26, 2021 at 4:50 am
albin.linderstam
Thank you for your answer and tips about the course.
For this simulation I assumed that the four bolts were strong enough to avoid the fixture from moving, hence Fixed at the surface between washer/fixture.
Thank you for your answer.
Perhaps I misunderstand you, but If I suppress the washer surfaces and the solid part in Ansys Mechanical, nothing is left.
Yes, it is doable with Bodies in Catia, thank you.
I haven't been able to find that license; if you talk about a license in Catia? Or do you mean in Ansys?
