Ansys Learning Forum Forums Discuss Simulation LS Dyna Accessing LS-Dyna Explicit Solver on Ansys Reply To: Accessing LS-Dyna Explicit Solver on Ansys
Andreas Koutras
I tested the APDL Product Launcher in versions 2021R2 and 2020R2 and works for LS-DYNA. Can you upgrade to a newer versions? Alternatively, you can run LS-DYNA with LS-RUN. I see that it is included in the installation packages of 2021R2 and 2020R2. I hope this helps.
