Ansys Learning Forum Forums Discuss Simulation Fluids Is it possible to compile an UDF to alter the height of vertical wall during the course of solution? Reply To: Is it possible to compile an UDF to alter the height of vertical wall during the course of solution?
I assume this is transient. In that case you could also split the mesh or relabel a zone(s). To do this accurately you'd need to pre-plan the positions to then split the mesh afterwards.
