Ansys Learning Forum Forums Discuss Simulation General Mechanical Coordinate system transformation for non linear analysis Reply To: Coordinate system transformation for non linear analysis
Aniket
which results are you referring to here? Let's say you are referring to deformation results, in any analysis, the solver would calculate the final position of the nodes, and total deformations would be simply the distance between the final and the initial. This wouldn't change even when you change coordinate systems.
-Aniket
