Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to model the lamination core structure that contains corner region and straight region? › Reply To: How to model the lamination core structure that contains corner region and straight region?
Francoo
The problem has been fixed. The core of the solution is you need to bond the radial part with a specific relative coordinate system, so that its z axis has correct meaning.
