Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error report in multiphase flow simulation › Reply To: Error report in multiphase flow simulation
i.tamunodienye2
The superficial velocities are as follows
Gas superficial velocity = 8.8m/s equivalent of 7.620921 kg/s (mass flow rate)
Liquid superficial velocity = 8m/s equivalent of 276.6256 kg/s (mass flow rate)
I used ICEM CFD in this meshing. Never used Fluent meshing before. I did not try workbench meshing with this geometry.
...and for the first few diameters plus at the bends. Patch in the near inlet cell to be the correct phase for the adjacent inlet too.
I am not clear with the above statement. Is there diagram to explain this?
